gonzalez3346
Thread starter- Joined
- Aug 28, 2013
- 20
Hello Everyone,
I have a 23 Sea Ray Sundancer I/O Mercruiser 1994 5.0 V8 Serial Number 0F132208. Last season my temperature gauge started to raise at idle and as soon as I open the throttle the temperature will go down to normal operation (160-170 degrees). I then used an IR temperature gun to see if I had a problem with my raiser and or manifold. (Everything checked okay). I decided to replace my raw water impeller at the out drive unit thinking that that was the problem. Well the impeller was okay and the problem persisted. I ran the entire last season with the problem since my engine was operating at the normal temperature based on the IR gun. Of Course I did not let the temperature raise over 175 by either opening the throttle or just turn the boat off (Remember the problem is only at idle).
This season I decided to tackle the problem and started by replacing the raiser and manifold just as a prevented maintenance. They both were in good condition but swap them anyway.
I also replace the Thermostat with a 140 degree as suggested by the manufacturer.
I also replace the temperature sender electrical component.
I also back flushed to see if the Power Steering cooler was clogged (was okay and not clogged)
I also check all my hoses looking for and obstruction (no obstruction found)
After all this component change and triple checks I found no problem but the temperature continues to rise over 180 going into 210.
Again I used the IR gun and the riser, manifold, temperature sender, thermostat and all hoses read at normal temperature or between 140-150 degrees.
I did notice that the circulating water pump was reading in the IR gun at about 170 to 180 degrees I do not know if that is a normal temperature for the water pump. (The boat was running for about 10-15 minutes connected to a water hose)
What else can be causing the temperature to rise? Can it be the circulating water pump or even the temperature gauge? How to check those are okay? I already spend over 1k trying to pin point the problem with no luck...
Please help! Any recommendation?
Thank you all...
Thank you all...
