BajabossJD
Thread starter- Joined
- Jul 10, 2011
- 138
Hey guys!
Can someone help me figure out a weird ignition / spark problem I'm having after swapping a 2004 5.0 TBI engine to a 5.7 engine w/ #1409 Carb setup? Everything is in and hooked up.. I replaced the stock Merc electronic pump with an electronic pump for a carb (7 psi). I'm getting fuel, I have spark, the long block is new (880 Block). Cranked it up and it sounds like the ignition is not letting it fire. There may be a backfire through exhaust but it cranks and cranks. Set #1 to TDC. Cap and rotor pointed at #1. The swapped over Distributor, Coil and Ignition were working perfect on the boat before the 5.0 lost a cylinder due to water through manifolds / risers.
In the engine swap process I installed new Pioneer timing cover without the crank sensor port. I knew the carb setup didn't need it but now I'm thinking the ignition is in limp or error mode without a sensor connected to it. Timing light shows I'm getting spark but it refuses to fire up.. Do I need an older style distributor for this setup? I assume the Thunderbolt V ignition is fine with the carb setup? I have a scan tool for the Thunderbolt V system but I had to order a different connector to hook up to this one.
Thanks!
Joe
Thanks!
Joe
