helping a good friend on this one. 1999 merc 5.0 with thunderbolt ignition , from what he told me the boat was running great all summer, the lower unit went out and from the rookie mechanic install a new drive , it pure misfire backfire. i went to have a look, when they could not get it started.i dont know what the hell they was doing messing with the wire harnest, they have a ground wire going to the negative side off the coil . i have the grey wire from the ignition box going to the negative side off the coil now it started . all the spark plugs was black i meant real black . i install new one , took it for a ride and still backfire under load, i get the carb rebuilt still backfire under load . could it be the coil ?? or the ignition box, i also check the firing order also new cap, rotor and distributor sensor. it start right up and sound great just backfire under load. what next guys. thanks much for any info.
