dlogvine
Master Chief Petty Officer
Thread starter- Joined
- May 4, 2015
- 839
Just got a Larson SEI 200 BR boat. with Mercruiser 5.0 V8 engine. At first thought that the starter does not crank, but when tried to turn the engine manually, realized it was frozen. So I removed the spark plugs, they were pretty rusty, and filled the cylinders with Mystery Marvel Oil. Let it sit for a day and managed to crank the engine, it turned with effort, but it turned. So my question is, is there any chemical compound I can use to unlock and clean the cylinders, would really hate to remove and rebuild the engine. Or should I just keep pouring mystery marvel oil and keep turning the engine until it goes lose?
Second problem is the lower outdrive unit, there is a little part of chipped right where the stabilizer fin is connected so that both holes are missing, the chip is about 5" by 1 and 1/2" size. Should I try to weld a piece of aluminum and put a new stabilizer on it or should I be looking for a replacement of the outdrive lower unit housing? If so where should I look for it? the cheapest one on ebay is about $150-200.
Thx
Thx
