Mercruiser 5.0 water circulator help
Mikeyd0703
Hey all. I have a little bit of a wobble in my water circulator pump. I sheared two belts in half already but Did not completley break in half. Is this a common problem or can this be another issue with the belt.
Everything else seems to be fine. I also see the belt moving closer to the front
Of the engine on the pulley. Can someone please help. If you need more info i can give more! Thank you
achris
More fish than mountain goat
Re: Mercruiser 5.0 water circulator help
.... I have a little bit of a wobble in my water circulator pump...
This is probably the cause.... Needs to be sorted or you will just keep breaking belts...
Chris......
Ayuh,... Any wobble is Bad, 'n needs fixin'...
