stormyj
Thread starter- Joined
- Aug 1, 2017
- 48
Hi all,
So, Im draining my blocks, closed system, for winter and pull the blue plugs from raw water side. Top plug, fuel filter box, water distribution housing, and there are two more plugs under the starboard side of the motor, on the raw water pump I believe. I do have seacocks supplying water to the motors, but even with the seacocks closed, water just keeps coming out of the water pump. I read somewhere that the impeller is between the blue plugs, so pulling the engine side plug will drain block, but not allow seawater to enter, pulling the other will let seawater to continue to come in. But with seacocks, I wouldnt think that would be a problem. Yes, the seacocks are closed. Any idea why the water still keeps coming in? Im pulling the boat on monday so I will take the seacocks apart and see if they are closing all the way. I thought that might be a problem. Any help would be appreciated.
thanks
thanks
