Mercruiser 5.7 L circulating water pump HELP
tacx
Hi All
Hope someone can help me out. I have a 1996 Mercruiser 5.7 L Alpha 1 Serial # 0F777836 that needs a water pump. So I bought new one online from Mac Auto Supply. Their pump description shows a picture of the pump (see attached photo), but the pump I received is not exactly the same as shown in their description. The pumps are identical except for the fact that the pump they show has two water ports. one with two bolt holes and one with three bolt holes. The one I received only has two bolt holes at each port.
All the research I have done ( youtube,and other suppliers) shows the the pump with the three holes?
So my question is, is that third hole required or will the pump I received work?
I'm hoping to install it this weekend, but the boat is at the cottage which is 300 miles away in upper Michigan and I would hate to make the trip with a pump that wont work.
Again, the pumps are exactly the same except for the third hole at the left port?
I appreciate any help
Sorry cant upload a photo, here is a link to the pump I purchased
https://www.amazon.com/Circulating-B...gateway&sr=8-3
Tom
tacx
UPDATE, After more research it seems this extra hole is called a "water bypass hole". And, there seems to be confusion as to if its needed on all engines. There are two numbers associated with these pumps. MPR2232MN is the pump with the "water bypass hole". MPR2233MN does not have the bypass hole.
But I cannot find which pump my engine requires? None of the part lookup sites indicate which pump is needed nor mention any of these two numbers?
The pump Mercruiser gives as a part number is 850399-1
Any input is greatly appreciated
Tom
