Winterized my boat last night as per manual and am happy with the result apart from the starboard riser seemed to have not a lot of water in it. I firstly removed the block drain plugs (starboard first), then removed the riser pipes (port first). When i removed the starboard riser pipe there was only a small trickle of water. Would the riser have drained through the block leaving only a small amount of water of could it be something else?
Many Thanks
Richard
Many Thanks
Richard
