Mercruiser 5.7L HP Rating ??
hwy39
I just purchased a 1996 Sea Ray w/5.7L Mercruiser 350CI. The horse power rating is 210HP. I thought the 5.7L basic was a 260 HP rating. What is the difference?
Wart T
Re: Mercruiser 5.7L HP Rating ??
I'd like to know also. My manuals show ratings of 235, 250 and 265. Sometimes I think they just pull those HP numbers out of their rear ends.
John_S
The '97 5.7L (2brl)/Alpha is 210hp in my op manual, '97 brochure, and Merc service manuals. Seloc doesn't have hp rating. Last I checked, the current production 5.7L (2brl)/alpha was 250 hp. http://www.mercurymarine.com/5.7l_sd_-_250_hp I also have been wondering about the differences, but suspect the current model has different heads or pistons (higher compression ratio), cam, and timing profile. It has a higher WOT spec, as well.
Wart T
Good info John. My information was from the Seloc, it doesnt list a specific HP for that year.
Thats odd i was almost positive the current 5.7's where gettin 260 at least thats what crownline with a bravo3 was advertised for. hmm
skicat
The HP is measured at the prop shaft. Therefore different drives give different HP's. <br /> <br />Alpha 1 250<br />volvo-penta 260<br />Bravo 3 260<br /><br />This is what I was told. Personally I think volvo fudged some numbers to boost HP and then Mercruiser did the same for their Bravo Drive to stay competitive.
cuzner
H.P. should be measured at the prop, but not always done that way.Could be some builders are giving out the engine hp, not useable hp....<br /><br /> just a thought<br /><br /> Jim
jimmbo
The pre Vortec 5.7 with 2 barrel carb were around 210 - 220 hp and 250 - 260 with 4 barrel. The Vortec 5.7 put out 250 - 260hp with a 2 barrel. Those Vortec heads flow real nice and allow higher compression without detonation. As for Volvo fudging the numbers. I have a Volvo 5.7 and there are some differences on the carbed engines. Mercrusier uses what looks like a standard 2 barrel intake manifold, Volve uses an intake that looks like the 1968-71 Z28 - LT-1 manifold. and a Holley 500 cfm carb.
hwy39
Thanks for all the input. I agree the difference is measuring the HP at crank vs prop which results in a difference of 260HP vs 210HP. If the 4-barrel carb puts out 250 HP at the prop vs the 210 I am currently getting, what all is involved in converting to a 4-barrel and is it worth it?<br /><br />Thanks,<br />hwy39
fast94impala
"what all is involved in converting to a 4-barrel and is it worth it?"<br /><br />hwy39,<br /><br />Just completed the conversion on my 96 5.7l Maxum SRL 2000. Well worth it!! Got another 5 mph and better launching for skiing. Hit 55 yesterday with full fuel and 3 people on board. 2 bbl was good for about 50. Plan on $600 in parts, $20 in beer and a couple evenings or a very full day of wrenching. All depends on how many brackets need to be modified. Unfortunately for me, it was most of them. Nothing a hacksaw and file couldn't fix. Really pretty easy to do.<br /><br />I went with Edelbrock 600 cfm marine(#1409) and dual plane manifold(#2104) for $295 and $159 respectively. Also purchased required square bore spacer and fel-pro intake gaskets and K&N low profile flame arrestor from Summitracing.com. The 4 bbl throttle bracket was obtained from mercruiserparts.com as well as new thermostat, sleeve and gaskets. You'll also need silicone gasket sealer, anti-seize, and teflon thread sealer. Happy boating!<br /><br />Mark
MFG197
What model Sea Ray? I have a 96 215 Express 350 Merc A1G2 250hp.<br /><br />I think I have a Weber 4bbl. which I plan on getting rebuilt. I think the accelerator pump is bad. Bogs down sometimes out of the hole. Still hits 50mph though.<br /><br />My original 1996 Sea Ray book says the boat was available with<br />4.3 V-6<br />5.7 v8 210 hp<br />and <br />5.7 V8 250 hp
hwy39
WWYC na7<br />Sorry for the long delay in reply. Boat is a 96 Signature 21' bow rider. 5.7v8 210hp. After reading all the info i don't beleive I will see any significant improvement going to a 4bbl. If mine was a vortec then I would
dygrp
Whats the difreance between 5.7 and 260 on a 350 ci engine. My engine only says 260 and the boat i used to have had a 5.7( both mercs)
skicat
5.7 is 350 cubic inches converted to liters<br />260 is the horsepower
tylerin
94 SeaRay 5.7 w/ a Merc/Weber/CarterAFB Carb (whatever you want to call it) 260 hp. WWYC use the Carter street/strip rebuild kit for your carb, much cheaper
dygrp
i thought so thanks for clearing it up, skicat
dygrp
another question, i just got this boat and the cooling hoses do not go into the exhaust manifold and exhaust elbow? i'll try to post a picture, previous owner has it returning to thermostat housing?
