mercruiser 7.4 beeping sound.
BigDog98
So i have a quick question. When i turn the ignition key, on my dash make a 2 beeping sound with 2 different tones and then stops after a second or 2. It always makes this sound before start up. All gauges show normal reading and it does not make any other noises besides that. Any idea? Thank you
Fun Times
The beeping at key up is considered normal as it's the warning system doing a self test telling you it's working correctly.
Also if you have a depth gauge (faria, hummingbird, etc.) mounted in the dash then some depth gauges may sound a beeping sound at first power up as well. http://www.iboats.com/Boat-Parts-Ac...earched.1--session_id.731992056?q=depth gauge
Horn Output, Possible Cause, Corrective Action, Engine Usage Available For Consumer,
Key on, beep for 2 seconds, then off. Normal test horn. No Action Required. No action required.
thumpar
Mine beeps when I turn the key on and they again as I start it. It is normal.
