- Joined
- Jul 18, 2011
- 18,137
Today was a perfect boating day . . . So, naturally the starboard engine would not start. :facepalm:
The Port engine started right up, but the starboard engine was having nothing of it. . . numerous attempts.
So, I called back to the house and told the family that it looks like a beach day instead of boating.
I got my computer/Diacom and hooked that up to see if there was anything obvious, codes, etc. No Codes
I tried feeding the engine some fuel, but it did not make a difference. So, I went about trying to verify a spark. It did not look like there was a spark (using a test sparkplug on the #2 plug position, since that is the easiest to reach)
I also checked a bunch of fuses, connections, etc . . . Everything looked OK - the fuses all tested out visually and by an ohm meter.
I got 12 volts to the coil and 12v coming out of the coil that leads to the distributor, as shown in the diagram.
The only thing left (it seems) is the distributor module, but it was getting late, so I'll check that in the AM.
I was able to verify the voltages that I was getting at various points around the engine harness by comparing them to the port engine. The port engine showed a nice spark on the test spark plug, the starboard engine showed nada, nothing on the test spark plug.
So, I thought I'd post this for the experts to see if I am missing something. or any other ideas on what to check. :noidea:
Calling . . . achris alldodge Scott Danforth muc
or anyone else ?
TIA for any ideas . . .
BTW - the distributor module looks a little pricey and not highly available ( :noidea: ) I would think there is a GM equivalent . . .
or anyone else ?
