711KMD
Thread starter- Joined
- Jun 7, 2014
- 5
Aye - So, I've got a 2000 Mercruiser 7.4 MPI. First start up of the season, I had a steady single beep alarm. Yes, the Outdrive fluid alarm. Cleaned and refilled old bottle, no change. New bottle, no change. After banging my head through this that and the other, I started noticing it would not beep sometimes depending on which battery I started on. When it does beep, it idle's like crap. RPM's surges and almost dies like my old carbed 454 when it was running crappy, voltage surges, all other systems fine. I eventually figured it would always start and run fine on battery 2, never on 1 or both. It got me through. I'm out of the water now and it just beeps every 3 out 5 starts. I got it running right and then ground out the bottle wires, I got the alarm to sound, but it did not stop when I broke the ground. It also beeped again after restarting. It never stops once it starts no matter what I do.
I've attached my Diacom report. The alarm sounds weakish sometimes like it knows it should not actually be on. The engine runs amazing when it starts right. I almost want to think it's in my ignition switch as it's the same test alarm as powering on the ignition, it just doesn't stop after engine starts.
Thanks for any thoughts
