- Joined
- Jul 18, 2011
- 19,649
Well, I did my end of season compression tests on the engines today. The port engine seemed to be OK . . . The Starboard engine, not so much :facepalm:
While the compression numbers look OK (not great) I did a cylinder leak test on the starboard engine, since the numbers were a bit lower than the port engine.
Here are my numbers
Starboard Engine:
1 = 125
3 = 124
5 = 118
7 = 117
2 = 124
4 = 128
6 = 127
8 = 128
Port Engine:
1 = 137
3 = 129
5 = 126
7 = 135
2 = 140
4 = 134
6 = 133
8 = 140
Engines are closed cooling system - including exhaust.
So, the cylinder leak test on the starboard engine showed a fair amount of leak on # 5, # 7, #2 , #4, and #6 had 80% leak . . .
Seems to be the exhaust valve that is leaking on #6 . . . I did not check the others for source of leak.
The port engine appears to have received a valve job at some point in the past, whereas the starboard engine is probably original (830 hours, 18 years)
Anyway . . . looks like I should do a valve job on the Starboard engine (oh joy) . . . My plan is to try to buy a set of built-up cylinders heads (iron) and do a swap of the heads. Then get the old ones re-done and swap out the port engine in another year or 2.
Couple of questions . . .
These are 'Gen 6' BBC (454) engines. I want to see if I can get off of eBay (or elsewhere) a set of rebuilt heads. I suppose I can get the casting number off of the existing heads. There are all kinds of BBC heads that have been made over the years. Anyone have any good cross-reference resources for compatible heads for the Gen 6 engines? Serial #s for the engines are in my Sig below
Anything else that I should consider, other than get a sailboat :noidea:
Here are my numbers
Starboard Engine:
1 = 125
3 = 124
5 = 118
7 = 117
2 = 124
4 = 128
6 = 127
8 = 128
Port Engine:
1 = 137
3 = 129
5 = 126
7 = 135
2 = 140
4 = 134
6 = 133
8 = 140
