salvageyard saviour
- Joined
- Oct 28, 2018
- 174
Not likely the flywheel could come loose. To be honest, I've personally never had a ring gear break off either.I don't think so, but is it possible the flywheel could come loose from the motor?
I actually just took a video of the engine cranking over with plugs out, cranks fine but it does make a weird noise.
Any ideas what's causing that noise?
Read about it a couple times on a hot rod forum, they were also discussing big block Chevys.
Hard to tell, but that doesn't really sound starter pinion teeth grinding. They have more of a clanking ringing sound.
