Mercruiser 7.4L EFI: Choosing The Correct Oil Filter For Filter Relocation Kit???
Greg_E
I'm in the process of purchasing a 1997 boat with a rebuilt 7.4L engine. The oil filter relocation kit that is installed uses 3/4"-16 spin on filters so I think it an aftermarket kit.
The Mercruiser filters are 13/16"-16. I could not find the specs for the Mercruiser filters, but I was able to cross the Mercruiser part number to WIX 51086. I then searched through all the 3/4"-16 WIX filters to find a filter with similar specs to the Mercruiser filter.
The Wix 1393 or 1393XP (synthetic filter media) look like possible candidates but they have a 30 lb bypass valve and it does not appear the OEM filter has a bypass valve. They all have anti drain back valves. Also I noticed that all the filters that I looked at with 13/16"-16 threads flow 9-11 gpm max and all the 3/4"-16 filters flow 7-9 gpm.
I chose that filter because it is the best quality and had the highest bypass pressure and was the longest filter for the maximum amount of filter media. Any reason not to use that filter?
Edit 3/8/18:
I spoke with the WIX technical representative on the phone today. He did not recommend the XP filters for boat engines. The XP filters were designed for use in cars and light trucks running synthetic oil providing the ability to increase the oil change interval. The synthetic media is backed up by a screen to make it a more robust filter that can withstand the longer service intervals.
The standard WIX filter (equivalent to the NAPA Gold) has a lower micron ratiing than the XP. If you look at the specs for the XP filters you will notice that they do not list the micron rating. As the filters collect particles they actually get better at filtering out smaller particles up to a point. If you are using a filter with a bypass and it gets so dirty that the bypass opens then the filter is no longer doing its job. The bypass may save the engine from catastrophic failure if the filter is changed in time, but while the oil was bypassing the filter, it was causing wear
Also he said don't get hung up on the better flow rating of the filters with 13/16'-16 vs 3/4"-16 nipple. The limiting factor is the 1/2" line going to and from the remote filter assembly. It doesn't matter which one you use, you will only flow 5-7 gpm through the 1/2" line.
Due to the severe duty of a marine engine he said just use conventional oil, and change it and the filter more often. If you used an XP filter it would be a waste because the oil will be spent before the filter. With the larger micron rating of the XP it is probably just getting to the point when it is doing its best job of filtering the oil.
I think that was everything. He was throwing a lot at me at once. If you have questions send them an email. They are happy to help and can explain it better than me.
use this to find a filter. http://www.wixfilters.com/Lookup/FilterBySize.aspx
no problem to use that filter. could also use the racing filters depends if you have a bypass in the block or not
however the 3/4-16' thread is common for an automotive re-lo kit I have a two-filter head. stock pump running 5000 RPM or less wont flow more than 8 GPM before your bypassing at the pump anyway unless your bearings are sloppy
Greg_E
Thanks Scott. That is the link I used. There are many filters that would probably work, as long as the gasket seals on the housing. I tried to pick a filter that was closest to the OEM spec, and also the longest filter I could find, so I have the largest area of filter media in the smaller diameter filter.
For anyone interested The WIX 51393 crosses to NAPA 1393. The WIX tech recommended a 51515 which is a more common filter and probably more readily available
if you want OEM spec, its the cheapest one they can get..... LOL
I myself am running a twin filter remote head on the new motor. figured the head was an extra $10 over the single and I change oil twice a year, so the extra $8 for the second filter is cheap (considering I have 10 quarts in the system between plumbing, oil cooler and pan).
Greg_E
You got that right!
The engine has 50 hours on it and the filter (not OEM) is about the cheapest you can by. I'll stick with the NAPA/WIX.
You will probably be hearing more from me when I get the boat. Always had outboards so Inboards are new to me.
Greg_E
Scott,
I was reading through your engine build thread and page 16, posts 226-230 discuss oil filters and oil flow in a BBC. You stated that the BBC oil pump had max flow of 15 gpm. You are using two filters (7-9 gpm each) which would cover that flow.
rate but I only have one.
The 51086 which is the WIX equivalent of the recommended Mercruiser filter with 13/16-16 nipple is only rated for 9-11 gpm which doesn't seem right if the flow rate of the pump exceeds that value. I want to get the best filtration I can but not at the expense of limiting the flow of oil through the engine.
I can get a dual filter setup if that's what it takes.
Needless to say, I'm confused.
I think the WIX tech cleared this up for me. The flow is limited by the 1/2" lines. I would think that is true provided the filters are changed at regular intervals before they restrict the flow. (See my additions to post #1)
