Apollo75
Thread starter- Joined
- Sep 2, 2009
- 272
All went well with installation of lower unit --- Thank You -->ZIGGY
1975 888 serial# 42....
Tried to install new Solas Prop 4-blade 14-3/4" x 15" part number 1513-148-15 that I purchased to replace my three blade with nicks in it --- my fault
Prop will not go down far enough to install splined washer onto splines --- checked everything --- remove thrust hub and the prop goes all the way down --- is there a thinner or smaller thrust hub I need ?
Also, when I turn the prop in neutral I hear what sounds to be like a faint clicking/rubbing of the sliding shift clutch --- only thing I can think of that might rub --- is this normal or do I need to adjust the shift cable or replace said cable ?
Thank you for your kind attention
OFM
OFM
