Mercruiser 898 timing settings
greg82255
Hello,
I have been digging through the archives and can't seem to find this question. What is the correct setting for initial timing on a 1982 Mercruiser 898? I've heard 8 degrees BTDC is about right, but I just want to make sure. The timing mark only reads 8 degrees BTDC to 8 degrees after TDC. I have also heard that you are supposed to set the advanced timing instead of initial. Which one do you set, and what is the correct spec?
Any help is appreciated, thanks.
Blk-n-Blu
Re: Mercruiser 898 timing settings
8* BTDC in gear at proper idle is how I set mine
greg82255
Proper idle being around 750?
