mercruiser 898, won't run (or will barely run), at wit's end
jpw1400
This is a 1981 Mercruiser 898, GM 305, 2-barrel Rochester carb and Mallory distributor, Pertronix Ignitor II points conversion, Pertronix Flamethrower II coil, MR outdrive on a Sea Ray V197. Ignitor module is powered through a relay and getting direct battery voltage when key is in "Run" position. Only non-ethanol fuel from marina.
Have had boat 4 years, and it's been great and reliable up until last few weeks of this season. I've been at this for about 10 days now, and I just can't figure out what is wrong. Local marinas have a long wait list to look at anything, and the place I used to go is under new management and won't work on anything older than 2000. I'm getting desperate, with the season quickly coming to an end. Any help is much much appreciated.
I *think* I've got a spark issue, but I'm not experienced enough to know for sure. I have what looks like good spark coming from ignition coil, but I don't have good spark at the plugs.
To baseline, this is what I'm perceiving as good spark coming from the ignition coil and bad spark at the plugs:
Coil test showing good spark from coil: Attached, and at
Spark test showing irregular spark at plug: Attached, and at
Distributor spinning when engine cranks: Attached, and at
Possible hint: While still not running anywhere near correctly, it seems to be a little closer to running, and might run for 30 seconds or so, on the first try of the day. After that, it will rarely catch. I can pump the accelerator pump and see fuel come out, let it sit for a few hours, but no change.
I had no reason to look for electrical problems other than process of elimination.
This is the chain of events, which I understand may be tedious to read through.
No modifications this season or last. Boat was running great for months. Once in a while would bog down when accelerating, usually after boat had been running, then stopped, then loaded up with passengers/gear or fuel. Would work itself out after a minute or so and then run fine. I presumed a carb rebuild was in my future. In the mean time I changed plugs and wires.
Some weeks later, boat would only start if I caught it just right, with a lot of throttle. Had been running great and almost daily right up until then. Once started, it would run fine. This happened for maybe three outings. On the last outing, I got a rope caught up in the alternator and shredded the belt. Alternator seemed unharmed, I replaced belt in driveway, boat ran fine in driveway (on muffs), but then had no power and would eventually stall when in water. After some diagnosis found that one-year old ignition switch had failed, and had no continuity in "Run" position. Replaced switch, boat started right up, ran fine in driveway, put it in the water, and then same thing: no power and would quickly stall and die.
Presumed it was time to rebuild carb, and did so. Didn't find anything wrong or dirty or blocked, but rebuilt it anyways. Boat would start up fine in driveway, but then had no power and would eventually stall when in water. Rebuilt carb again, and did find that I had not properly set float, but was meticulous this time around and everything set correctly. Verified there is fuel in fuel bowl. Verified that fuel squirts out from accelerator pump. No change in behavior.
Tried spraying starter fluid direct into carb while cranking. No change in behavior.
Since then, trying to find something wrong in the fuel/air/spark area, I have:
Replaced distributor cap. Old cap and rotor looked fine, but carbon button on distributor cap got stuck when I was testing resistance, so I replaced. Polished up rotor cap. No cracks or burns or anything that seemed bad. No change.
Found some poor connections when testing continuity and replaced power wire to coil. No change.
Verified distributor is well grounded, and there's no resistance between ignitor plate and battery negative or engine block.
Replaced coil. Went with Napa IC12 with external resistor. No change.
Pulled fuel lines, and tested fuel pump. Tests at 5 PSI. Tested that sufficient fuel volume is pumped out from fuel pump. Tested just fine.
Swapped in a Petronix ignitor I had on hand. No change, so reinstalled the Pertronix Ignitor II I've been running for past 3 years.
Pumped some fuel into a clear gas jar for inspection. Looks perfect. No water, no sediment or debris or cloudiness or anything other than clean fresh gas.
Tried to pull distributor for inspection, but there's insufficient clearance in the boat to fully remove. I reinstalled, with 8 degrees BTDC on cylinder 1. No change.
Replaced coil back to the original Petronix Flamethrower II. No change.
Tested resistance of wire from coil to distributor, which tested fine (500 ohms). Swapped in a new wire just in case, and no change.
The only thing I can think of that I have not tried is hooking up an external fuel tank, but at present I think spark is my issue and I have verified fuel and fuel delivery looks good.
Changing distributor would be very difficult, as there's no clearance to remove. Would involve basically pulling the engine from what I can see. I don't want to go there unless there's good reason to think it is a faulty distributor.
If reading this, I would assume the poster unnecessarily rebuilt the carb and screwed it up, but I've checked and rechecked my work and I can't see any mistake.
I'm thinking that something is getting warmed up in the distributor and somehow preventing regular spark out the distributor cap, but I can't think of what that might be.
Thanks for any thought or comments,
Jim
  • coil test.mov
  • inline spark tester.mov
  • Distributor turning.mov
dwco5051
I am not a fan of neon spark testers. Test it again with an adjustable air gap tester and tell us how far a nice blue spark it will make.
Don't think its fuel, more likely spark.
If Tach is connected, disconnect
It doesn't sound like fuel to me either. Is the choke closing when the engine is cold and the throttle is pumped? When you have to put the throttle in WOT to get it started usually that's a sign of being flooded. What brand of spark plugs are you using.
jpw1400
It jumps 20K to 25K. I haven't seen it jump more than 25K.
  • Adjustable air gap.mov
jpw1400
Choke is closing when it is cold and I pump the throttle, as it should. When it was running OK in driveway, choke (electric) was starting off closed like it should, then opening up after a couple of minutes. The only clear fault I can find so far is the engine doesn't run. :)
(Thanks for all comments, and please keep them coming. Apologies if my replies aren't showing up attached to the correct post... I'll make a reference to the post I am replying to just in case it doesn't link correctly.)
jpw1400
"What brand of spark plugs are you using."
NGK BR6FS, since about 2 months ago. Replacing the spark plugs was something I did early on, after it bogged down once or twice, at wife's suggestion. Seemed to help, but I think it may have just been coincidence in retrospect.
jpw1400
I'm seeing orange spark and its not consistent
Agreed, but I'm having trouble with the "why". Coil test (shorting to engine block) looks consistent; I can't tell if it is strong or not. I can say it looks the same whether I use the existing coil or the new one I put in when I was hoping it was caused by a bad coil. Is there a better way to see strength of spark straight from coil? I tried hooking it up to the adjustable air gap spark tester, but the fitting is not the same and not making a good connection.
  • coil test.mov
If there is good spark and fuel, the next thing would do a compression test
Don't like using Either but in this case would be a good test. Don't use much, and if you can start cranking before giving a quick short bust
jpw1400
Did compression tests when I changed the spark plugs (~2 months ago). All cylinders were in range and consistent with each other.
I have tried starter fluid sprayed down the carb before/during/after cranking. Got a good bang out of the carb one time afterwards, but that was it.
Do others think (like me) there is a great inconsistency between the spark from the coil and the spark from the plug wire? If the spark out of the coil was inconsistent and/or weak, could we blame the Petronix Ignitor II? I've read that the Ignitor is never intermittent (it either works or it doesn't), but I've also heard there are some things on the internet that aren't true.
Incidentally, I still find it strange that my ignition switch, one year old, went bad (it has since been replaced with new). I started thinking that maybe there was a short in the "Run" wire, and that's what made the switch fail (though never saw any burn anywhere and fuse did not blow). So, I just tried running a wire straight from "Ign" on the ignition switch to the coil, but it didn't change anything. Had my hopes up there for a minute or two.
jpw1400
What were the ball park compression numbers?
I've been looking for my compression tester for the past 2 hours, and can't find it anywhere. I believe they were all between 110 and 120 PSI. I firmly recall being pleased with both the readings and the consistency. This was on a cold engine.
I will try to pick up a new gauge tomorrow. However, engine was running great until it wasn't. If I was dealing with a rough idle or occasional misfire I think compression readings come into play. But this seems to be something central, which would affect all cylinders.
set coil up with gap gauge and disconnect all wires off - post except one short wire. Connect 12V Battery to + side and then strike - side to ground to see what kind of spark you get and is it better then when distributor is doing it?
if the numbers are that low, you are borderline rebuild.
jpw1400
I first setup the gap gauge to the coil wire, and saw what looks like good consistent spark. This is in "coil.mov", attached.
I then setup the gap gauge to the spark plug wire, and again saw what looks like very inconsistent spark. This is in "from coil.mov".
I then did the test you suggested. Nothing hooked to coil except battery voltage to positive, gap gauge on the coil output, and a ground wire on negative I could tap against a ground. I could get spark if the gap was very low, but not otherwise. I suspect it is my technique on how I am grounding it out.
Something new is you can now hear my starter is tired. I'll check on that, but it is a new development and I don't think related to the other troubles.
It would be natural at this point that someone thinks "I bet he has a bad ground somewhere". Conceivable, but I did check that I have zero resistance between distributor plate and battery negative.
  • from coil.mov
  • spark plug wire.mov
