Ugarph1982
Thread starter- Joined
- Apr 8, 2017
- 16
Good evening,
I'm looking for a little advice on gimbal bearing installation. Quick context to question ... I have a 1988 Merc 3.7L tied to an Alpha 1 Gen 1. I've had the boat about 5 years and we run it quite a bit in the summer, and it has served us well. I have re-sealed the outdrive before (carrier bearing seal -- oil in bellows), I change the impeller and housing every 2 years, and I keep up with all of the routine maintenance.
Concerning the gimbal bearing ... I put in a new bearing 2 years ago when I changed out all of the bellows. I opted for one of the sealed units, rather than one that is serviced through the zerk, because it sits in the water all summer. I put the supplied plug in the zerk fitting.
Today we were out for an early season boat ride ... Got her fired up and accelerated for a test lap around the cove. About 60 seconds into the ride, some *major* bearing went to shrapnel. At first I thought it was a rod or crank bearing in the motor, but all oil pressure and temperature indications remained stable as I limped back to the dock. The boat was shifting fine as well, as I put it in reverse to dock it.
I believe that the gimbal bearing crapped out on me, given the deep moaning and roaring sound it was making. I'm actually hoping this is the case. I already pull the drive off every year to grease the u-joints and check alignment, so putting in another one should be easy-peasy. Once the drive is off, it will be easy to identify the motor, the stern drive itself, or the gimbal bearing.
The reason I'm posting here is for advice on installing the new gimbal bearing. When I installed the last one, I just wasn't satisfied with the seating of the bearing and alignment processes. I used an appropriately-sized seal driver to drive the bearing into place. Once it was seated, it took a fair amount of jimmy-ing it around with the alignment bar before I could easily slide the rod into the coupler. I felt like I was torquing the crap out of the bearing, and perhaps that's the reason that it (possibly) failed early. What advice does anyone have that has installed a million of these things?
My whole diatribe could be moot if I find out my mighty 3.7 has taken a dump ... In which case it will be the end of an era. I'm pretty confident in my gimbal theory, tho.
Thanks in advance!
Russ
Thanks in advance!
Russ
