achris
More fish than mountain goat
- Joined
- May 19, 2004
- 27,468
Correct.You don't need to worry about that. Personally I wouldn't mess with it until I needed to. Might replace it at that time. It isn't affecting anything.
Gimbal bearing is affected by water in there, but not the cause. If that's gear lube mixed with the water then it's an input shaft seal in the drive. If it's actually grease, then the drive is ok. Either way you have water in your bellows, which can be a breach in the bellows, water in the boat going backwards (needs to be a lot of water), water getting in through the fat seal between the drive and bellhousing... Probably other ways that I'm not thinking of.If its water mixed in with grease, so that sounds like gimbal bearing and bellows. Pressure test to check seals?
No smell! I'll take that as a good sign, and just focus on a gimbal bearing and bellows job.Take a swipe of that slurry in the bellows with a finger and smell it. Grease will be almost no smell at all, while gear lube stinks bigly.
Definitely replace the gimbal given the rust and moisture in the grease. One other way to get water in the bellows is through the shift shaft theres seals where it pivots through the exhaust passage the top one can let water into the bellows if the big square gasket leaks .No smell! I'll take that as a good sign, and just focus on a gimbal bearing and bellows job.
Thanks, this is different than the shift bellows the shift assembly runs through, the seal depicted as part #4, correct?Definitely replace the gimbal given the rust and moisture in the grease. One other way to get water in the bellows is through the shift shaft theres seals where it pivots through the exhaust passage the top one can let water into the bellows if the big square gasket leaks .
Yes, if that's leaking though your shift shaft cavity will be a mess. #9 and 4 are sold together now, you need to press it in. Exhaust bellows leak wouldn't cause an issue.Thanks, this is different than the shift bellows the shift assembly runs through, the seal depicted as part #4, correct?
Yes.Is the Sierra kit of similar poor quality too?
I'm on season 3 of a sierra kit without problemsIs the Sierra kit of similar poor quality too?
