Do I need a special tool to remove the prop?<br /><br />I have ran the motor with muffs on in the yard in neutral. Can you also put the motor in gear while you are using the muffs or is it bad to have the prop rotate out of the water?<br /><br />Can I take the prop off and put it into forward and reverse?<br /><br />I want to test a new lower unit install.<br /><br />Thanks for the help,<br />ScAndal
