MerCruiser Alpha 1 running hot
Don S
Re: MerCruiser Alpha 1 running hot
With your laser gun, shoot right at the base of the temp sending unit for closest results. That should be what your temp gauge on the dash reads.
eriefeelin
Update. I finally had a chance to get the boat out on the lake today. Before doing so I cleaned up the poppet ball valve assembly.After coming down off of plane with the gauge on the dash reading close to 170 degrees I put the IR gun right on the brand new sending unit and it read from 136-145 degrees while running about 1300 rpm. The 170 reading on the dash gauge hardly moved if at all.
The elbows had a reading of about 125-135 degrees with the post side a tad higher. The exhaust manifolds had a reading of 185-200 degrees.
When I installed the new thermostat I cleaned both mating surfaces good and used a new gasket with the 4 copper rivets in it that serve as a ground. Before I replace the gauge on the dash as it's 19 yrs. old I might try adding a ground wire right to the sending unit and see if that makes a difference.
eriefeelin
I replaced the gauge and all is well. Now it reads around 150ish while idling at the dock. Need to run it out on the lake to make sure.
