kippstakes
Thread starter- Joined
- Jun 10, 2013
- 117
Gimbal bearing seems to have gone bad, boot needs to come off. Boat is in forward gear (and I have tried in reverse gear also), all bolts are out, trim rams are off.
The upper unit easily breaks away from the gimbal housing at the flange (correct my terminology if wrong), but will ony pull away less than an inch before sticking in place. It seems to be binding on something inside, that's my guess anyway. Seems like a straight forward process, I can't imagine that the drive shaft is locked up, it almost has to be the shift linkage. Again, I have attempted this in forward and reverse gear positions with no success.
Any ideas??
Thank you
Any ideas??
Thank you
