mercruiser bravo 2 outdrive trim up w/o pump??
slick245-ss
is there a possible way to trim up the outdrive without power?? I'm in the middle of a rewire & want to service the outdrive oil/impeller:confused:
Re: mercruiser bravo 2 outdrive trim up w/o pump??
Ayuh,... Welcome Aboard,... There's No impeller in a Bravo drive, the pump is motor mounted,...
'n the drive wants to be Down to change the oil,...
To lift it, Jumper the trim pump up,...
