Mercruiser carb rebuild but hard start and idle
MilleniumFalcon
I have a 1989 mercruiser 5.0 serial number B903262. After a season of losing power, hard starts, rough idle, engine stalls, and black smoke I decided to pull the carb and rebuild it. This is the first time I’ve done this and the kit seemed pretty simple. Now with the carb back on, I can’t get it to start without having the choke plate propped open and it will die if the plate closes. I’ve replaced spark plugs and wires, fuel lines, fuel pump. The carb was definitely a mess when I pulled it apart. The boat ran fine most of the season but I think I had a wire go bad to a spark plug and that’s when I decided to look at the carb. Adjusting the idle mixture screw does nothing but adjusting the fast idle so the throttle is open more seems to help it start and run.
Bt Doctur
If the fuel delivery is more than adequate a motor may not need full choke to start. A cold motor may need choke
MilleniumFalcon
So I understand, you’re saying a cold start might not need full choke? If that’s the case, does that mean I shouldn’t set the choke to close fully?
Bt Doctur
If you can have the choke open to start a cold engine the carb is delivering more fuel then needed for a cold engine.
You set the plate to close on a 1/8th inch drill bit on a COLD engine.If you have to hold the choke open to have the engine run, you have a carb problem
MilleniumFalcon
If the carb is delivering too much fuel, what can I do to resolve this?
MilleniumFalcon
The float level is set according to instructions but I have read that the original floats could go bad. I put this float in gas to make sure it floated and it did fine. Should I try a new float and reset it?
Bt Doctur
from manual 15
MilleniumFalcon
The set that came with the Sierra brand kit specify 9/16” level and 1-3/32” drop measuring from the toe.
alldodge
Sierra that's kind of funny but your measurements are off when compared to manual 15
A whole lot of difference between 9/16 and 3/8
What kit number did you use and what type of needle seat?
Click image for larger version  Name:	89 Crab.jpg Views:	1 Size:	59.3 KB ID:	10638570
MilleniumFalcon
I have the spring loaded or solid. The original was solid but I placed the spring loaded in per the recommendations. In the instructions posted here it recommends the solid 2 piece type. I can change that and readjust the float.
alldodge
Using the spring loaded, then the 9/16 may be correct, and without gasket.
The issue still seems that the float is either not sealing the fuel off, or an incorrect measurement
MilleniumFalcon
So the carb works by a vacuum sucking fuel down from the supply in the fuel bowl? If the needle isn’t cutting off the supply then the vacuum would continue to draw fuel also supplied by the pump and cause a flooding effect? The carb is needing to overcompensate by adding more air to counteract the amount of fuel? Does this sound like the cause for me having to hold the choke plate open?
alldodge
No
The motor is drawing fuel by vacuum across the venture's. The vent's are connected to the carb float bowl chamber with passages. If the fuel in the float bowl is higher then spec, there will be more fuel sucked in then needed.
If bowl is less then spec, there is to little fuel. I'm seeing to much fuel so the bowl level is to high
dlogvine
Master Chief Petty Officer
Sorry to bother you, but did you say you used the old float from 1989 carb, when you rebuild the rest? If you are using the old float this could be the problem.
dlogvine
The float might look ok but if it is old it might lose its buoyancy and it gets more fuel to stop its flow into a fuel bowl.
MilleniumFalcon
I've ordered the new float and will be installing in a few days when it comes in. I'll update after this. I really appreciate all the advice and I'm hoping for a good laugh if after all this, skipping one simple and cheap step has stopped my boat. I'm confident after replacing and adjusting the float properly, this thing is gonna be back at it! Thanks!
