mercruiser carb, rochester, 3.0 4cylinder, adjustment questions
potatoe
i have recently purchased a remanufactured carb for my mercruiser 3.0. my old carb had only one adjustment screw, besides the idle. the new carb has 2 adjusting screws, side by side. can anyone explain these to me? how to adjust them? im leaving it to the pros, but i do want to know. what happens when opening and closing these? thanks
Don S
Re: mercruiser carb, rochester, 3.0 4cylinder, adjustment questions
You bought the wrong carb. You had a Mercarb, you bought a Rochester. Merc stopped using the Rochester a long time ago. Early 80's I think.
potatoe
is this a crappy carb? will it not work? thanks
Don S
You've got it, try it and find out.
dubs283
idle mixture screws
used for setting the amount of air/fuel bypassing the throttle plates at idle ONLY
turn clockwise to move in, counterclockwise to move out - note when the engine starts to stumble when turning either way, set at midpoint between engine stumbles
