Mercruiser engine and sterndrive oils
IanFS
Hi again guys
Mercruiser 4.3L '88 with Alpha One
I know that you guys will recommend using OEM parts i.e. Quicksilver/Mercruiser, which I always do. However when it comes to oil I'm sure Mercruiser don't have their own refinery. Therefore Quicksilver and Sierra will both have to have someone else refine their oils for them, like ExxonMobile or Castrol.
I can get some Sierra Synthetic oil now to what seems to be the same spec as Quicksilver mineral, so what do you Oracles think of Sierra oil? Both Stern Drive and Engine.
dubs283
Re: Mercruiser engine and sterndrive oils
use quicksiler high performance gear lube in your drive
unless you have a catalyzed engine, use any 25w-40, or SAE 30 oil in the engine
Levinz11
That'll work just fine. I use Mobile 1 in mine and change it at the recommended intervals.
