mercruiser engine harness?need a part #
betayv
hello there I have a 1995 mercruiser engine 5.0 I need the part# for the engine harness the female and male I guess. I need the complete harness thanks.
Bt Doctur
Re: mercruiser engine harness?need a part #
That could be expensive, what is wrong with the plug/harness now .
You could convert to a terminal strip or solder the wires together and heat shrink them.
tractoman
There are many aftermarket quick disconnect type plugs that would also do if that is a requirement. Some also have rubber gaskets and are pretty water resistant. Maybe an option to OEM.
Don S
IF you do want to buy a complete harness, do it by Merc serial number only DO NOT go by year alone. There may be several different versions.
betayv
thanks don Im sorry but for the serial number of the engine? thanks.
betayv
i will get the serial number from the engine thanks
havasuboatman
Ensign
Once you get the serial number, just call a couple of merc dealers and ask for a quote, AND the part number. Call around for the best price.
