Mechanic swaped 3.0 omc engine to a 3.0 mercruiser with the omc cobra outdrive. Took it out and it wouldnt go into reverse. Noticed the shift cable housing was broken right before the outdrive so we replaced the shift cable and had to adjust the linkage as much as possible and finally got it to shift into reverse, but now right back to no reverse after taking it out. I know the linkage mount is on the top of the mercruiser instead of the side of the engine like the omc. Does anyone know of any possible way to adjust the linkage or if it can even be done with a mercruiser engine to omc outdrive?
