mercruiser exhaust Y pipe help .
djmakko
I need some info from anybody that had any experience with exhaust Y pipe, for a 87 Mercruiser 260 5.7 sterndrive
my Y pipe its corroded on the lug holes, my part number calls for 44265-C . I found one in very good condition from ebay but his part is 44265-C1 would there be any difference or will it fit mine?
Help please!
What i have found is that -44265-C1 is for a 6 cylinder and 44265-C is for 8 cylinder?
achris
More fish than mountain goat
Re: mercruiser exhaust Y pipe help .
6 cylinder and 8 cylinder engines use the same exhaust pipe. Those numbers you're quoting are the casting numbers, not the part numbers.
The correct part number for your pipe is -44266T1, which supersedes to -807130A4. It's likely that the one he's offering is the later one. Find out what sort of shutters are in it. You should have the single piece shutter on a shaft. The later ones have the new style shutter, 2 sections either side of a hinge arrangement.
Chris.....
Post the ebay link and I'll have a look at the picture...
djmakko
Chris.....
Mercruiser Marine Exhaust Y Pipe 44265C1 44265 C1 44265 C 1 w O Baffles | eBay
i bought this shutters already-807166A3 that replaces 18-2732
achris
That's the old style pipe, should be a direct replacement for yours. And you got the right shutter kit for it....
djmakko
Thanks Achris, one last thing is this the way the supposed to be installed?
achris
Yep....
djmakko
Thanks for the help (Priceless)
