Hello,
I have a 2003 Regal 2860 with twin Mercruisers 4.3 MPI, Bravo III. I just noticed the bilge pump working every 5 minutes or so (just pumping a little water). I went under the engine and I saw water slowly dripping ( coming from the port engine...under the exhaust Y pipe). See attached picture.
Background: I bought this boat last year and used it for 3 months with no issues. I did not replace the bellows this spring. Note: A mechanic at a local marina replaced the steering cable last week (he had to remove the port engine exhaust hoses to access the cable area (but he forgot to tighten the exhaust clamps). The port exhaust hose was leaking when we launched the boat and he had to come back to tighten the clamps (not sure if this could cause a leak). I am 2 hours away from that marina and Im trying to avoid going back there. Terrible experience!
1- I just dont know if this leak is coming from the Y-pipe or (maybe) from the shift cable bellows. Can we tell the difference based on the origin of the leak?
2-If the problem is the exhaust (not the bellows) does it leak while the engine is off. I though the exhaust only leaked when you are running the engine.
Your input will be appreciated.
Luis
Luis
