The boat is a 1993 Crownline with 4.3L LX, I beleive it's a Gen 2 outdrive., the boat has 209 hrs
Have put less than 2 hours on the motor this weekend, but yesterday we launched for an evening fireworks cruise, and noticed a squeel, (at first just thought it
was the normal belt squeel I get every time it starts). Today I am thinking that maybe the squeel was a little different... then put the drive into reverse, and forward as we pull away from the dock, and things didn't act right.
the boat wasn't moving. I raised the lower unit to verify that the prop was in fact still there, and it was, but I was getting no shift sound as I moved in F or R.
At one point, when shifting into F or R, the motor stalled,
and I was thinking it was maybe the ignition, but soon realized I had lost something in the drive. We paddled back to the launch, and loaded the boat on the trailer and I had somebody get in the boat once we were out of the water, and put the lever in F and R... I turned the prop, and when in gear, I would get the normal ratcheting on one direction, but in the other direction, when I turned the prop, I hit resistance, which was normal, but then I realized I could keep turning, without a
huge effort. I had somebody in the boat check the motor
to see if it was turning, but it wasn't... So,,
I think I have a problem in my drive,, possibly gears, upper gears?
Is it possible for a bearing to sieze? then cause something to break? Is there any "coupler" that could be bad? (I think I know the answer to that)
I plan on doing some more investigation tonight, but wondered where to start.
I would feel comfortable taking the lower gearcase off,
and then removing the upper, but I don't think I would
be capable of rebuilding myself.,, seems to intricate for me, and I wouldn't have any special tools needed.
thoughts anyone?:'(
thoughts anyone?:'(
