Mercruiser High Oil Pressure?
NatedoggAZ
Hey all,
Went boating 2 weekends ago and I noticed that the oil pressure was fluctuating between 40 and 80.
I just changed the oil and filter - and this was the first time out since the change.
I'm guessing that possibly the sensor is acting weird...hopefully?
Where is this sensor located exactly and is it a pain to switch out?
Anyone know what part number I may need?
I guess I could also rent/borrow an oil pressure tester from Autozone or whatever to check it out as well - just not quite sure how to do that...
1988 Mercruiser 4.3
Serial Number: 0B847392
Engine model: 443S100AR
Thanks!
Bt Doctur
most times the sender is to the right rear of the dist facing the motor
Being a 1988 the oil pressure sensor will be in one of 2 locations. On top the deck below the distributor or port side down low next to the oil filter or oil filter remote adapter. It looks like a small can type
https://www.mercruiserparts.com/8m0068784-sender-assy-1
Remove the wire and turn the key ON, then ground the wire and the meter should peg high
Could be bad sender, could be sticking pressure regulator in pump, could be spinning bearing.
Install mechanical gauge to verify
NatedoggAZ
Thanks for all the help so far...
So - are there 2 separate components - a "sender" AND a "sensor"..?
Or are they the same thing?
ND
your motor being a 88, it should only have one sender (can also be called sensor) for the gauge
NatedoggAZ
Went out to the boat yard this evening and found the pressure sensor/sender - it was right on top of the engine to the right of the distributor and accessible.
The catalog says to go with Mercury 90806:
https://www.boats.net/product/mercury/90806?ref=682ece96460a0047d04608f040d299ff4eb47e05
Or Sierra 18-5899:
https://www.iboats.com/shop/sierra-18-5899-oil-pressure-sender.html
I ordered the Sierra part because it was a little cheaper...should have by Friday to install for the lake on Saturday =)
thumbnail
