Mercruiser hoses
sogood
Doing some improvements and replacing hoses is on the agenda. The boat has sat up for some time and some of the hoses don't look as healthy as I'd like. I was checking out the hoses on the manifolds and the two large hoses that run from top down are different, in that one seems to have a hard spring insert which you can feel when you squeeze the hose, whereas the other just depresses, with no obvious insert. Is there an insert or is this just a build up of some sort of debris/crud.
Thanks in advance.
Ayuh,.... Welcome Aboard,.... Whatcha workin' on,..?? Merc has built millions of motors over the years,.....
sogood
Sorry, it's a Mercruiser 5.7 circa 1990 with an Alpha Gen 1 outdrive.
