In going through this for the first time I found the water inlet hose packed with sand. It could not possibly have been getting much if any cooling.
On our first outing we got into a shallow silty area and again I found lots of sand in the cooling system.
There is no strainer on the intake and one of the fittings has an orifice about 1/8", presumably to limit flow rate.
Is this a common problem with this model or with outdrives generally? What's the solution? Should I put a strainer in the hose from the transom to the engine?
Thanks for any info.
Alan
Alan
