- Joined
- May 16, 2009
- 9,452
Re: mercruiser ignition control module?
If you set your meter to dc volts and connect the positive to the negative side of the coil and the negative side to a good ground, with the ignition "on" hold the white/green wire from the module to ground for a few seconds, if the voltage drops to 7-9 volts, then returns to 12, the module is good.
http://forums.iboats.com/showthread.php?t=444003&p=2970677&viewfull=1#post2970677
Another thing you may want to try is graphing out your engine timing with a timing light.
While in base timing mode make sure your timing is around 8-10 degrees before top dead center, then make sure it's advaning up to around 32 degrees at about 3500 rpm. Right now the idea is to see that it is advancing too??? At this time i'm not sure what your exact numbers should be on your engine, But this should help give you an idea as a starting point.
How to set base timing,
http://www.perfprotech.com/store/articles/mercruiser-engine-timing.aspx
Also check the actual temp of the module with a infrared temperature gun.
dubs283 described how to do this test the best.The only thing left is the ICM. Does anybody know if a merc dealer can run a diagnostic on the ICM to determine if it is bad or does it just get replaced when you run out of cheaper options?
