mercruiser lower unit impeller question
third times the charm
Okay pulled my lower unit today to inspect my impeller, just as i thought i couple of blades are gone and the rest are getting ready to go. Well when i pulled the two sections apart i noticed a large metal looking piece laying on the impeller housing. Now it flakes apart and looks like layers and layers of just deposits, is that possible and another question. My gear ratio is 1.84 with the serial #5218785, my boat is a 68 with the 120 hp inboard. It looks like the outdrive is off of a 470 mercruiser( according to the serial number and the gear ratio) Can anyone help me determine that for sure.
I have had teh boat running on muffs in foward and reverse, not hearing anything sounding like its going to fall apart
Re: mercruiser lower unit impeller question
I can find it for you, but you would miss out on a ton of great info in the process. :D
Here's a couple of links from the Adults Only sticky at the beginning of this fourm:
Miscellaneous Mercruiser Information
How to ID an Alpha Style Outdrive, and History.
http://www.4shared.com/file/21385430...nd_Histor.html
This can be used to check the year of your engine, drive, and transom shield by serial number.
http://www.4shared.com/document/TcRI..._SN_range.html
MerCruiser GM Engine Code Identification
Service Bulletin2005-08
How To: Replacing Merc Alpha style impeller
http://forums.iboats.com/showthread.php?t=387864
Hey Eric
Thanks for the links, I should've known don would've had something there in teh sticky
Reached my hand up into the upper drive section, alot of crud and more of that built up in there. I guess i can take my exhaust tube loose in side and flush it out with water or air. Anyway i should've looked first, thanks for reminding me:facepalm:
slim2005
I am new to the site, can someone point me to the links if they have been relocated as they will not work for me on the 4share site. Thanks for all the help!
