seven_magnum
Thread starter- Joined
- Oct 4, 2011
- 127
Hi,
I am currently restoring a 1976 Starcraft islander with a Mercruiser 165 (MC-1 outdrive) The engine is shot, and I am going to put a new long block in it's place. What I need help with is the other end of that system. From what I have been reading it seems a pressure test is in order, as well as shifting the outdrive and making sure the ratcheting is correct. Is there any other testing I can perform while the drive is off? Any potential problems to look for?
I will be replacing the impeller and fluid on the drive. For the transom assembly, I am going to install new bellows. Is this all I need to be concerned with? (Provided the drive passes the pressure test!)
Is there anyway to test this drive before I splash it? I Thank you very much for your help!
Foster
Foster
