Mercruiser MCM 3.0??
Tucksy
HI i've just brought a Fletcher GTS with a Mercruiser MCM 3.0 inboard the serial number is OC369282 but i cant work out the rough year of the Boat i think it's about 1993 but i want to know what types of oil it uses in the engine and outdrive as i want to keep on top of the servicing?
Any help would be appreciated thanks
Jerico
Re: Mercruiser MCM 3.0??
Check the top of this forum adults only thread for the service manuals (9?). Just on a guess, you need service manual #13.
Grumman59
Isn't the year of manufacture included at the end of the serial number, stamped on the starboard side of the transom of almost all boats? So the last two digits ought to be 93.
Fun Times
This serial number you posted is for your sterndrive, 0C369282 Model number 5010198AS MERCRUISER ALPHA 1.98:1. R.H. ROTATION.
The drive manufacture Date was on: 02/08/1988.
The name of the oil you will want to run in your sterndrive is called (Mercruiser high performance gear lube plus).
For this perticular sterndrive, The OP will need service manual part number 90-129342 SERVICE MANUAL #6 R/MR/ALPHA ONE.
As far as service manual number 13 goes for his engine, We will need to see his engine serial number to anwser that correctly, Because of the undetermined year of the engine/Boat.
Yes, normally the boats hull identification number is located around the starboard side of the outside transom area.
Normally the last two digits should be the year of the boat, my guess is, his should be somewhere around the year 1988.
Tucksy
Thanks for the quick replys.
The serial number on the transom is OC377891.
So will that make it a 91?:confused:
Fun Times
Nope that will not make it a 1991.
This serial number you posted is for the transom housing assembly This serial number is also for a 1988.;)
Next you will want to look for the engine serial number within the areas that they talk about in this next link. https://appcenter.mercurymarine.com/litreq/popSnLocator-mc.jsp
The below links will help you find your boats ID number on your transom if your interested.
http://www.dmv.ne.gov/dvr/pdf/hinplmtinst.pdf
http://kdwp.state.ks.us/news/Boatin...-do-I-look-for-the-hull-identification-number
http://www.google.com/search?source...boat+hull+identification+number+is+located+at
