benchircop26
Thread starter- Joined
- Jul 8, 2015
- 22
Hi,
A few weeks ago when I put the boat at sea, engine wasn't getting enough power (revs) but by time after some minutes working it starts to accelerate. I changed distributor cap and plugs and engine worked perfectly.
Next time I used the boat, it started to work very bad from revs 1700/2000 up to 3000 (missing really badly) once you pass the 3000 rpm it works fine but sometimes it misfires. I changed high tension leads, tried a new coil, plugs, tried another distributor cap + rotor, tried other injectors, checked fuel pressure and everything remained the same. I also did compression test and all cylinders are fine.
Can you please help me maybe you had a simlar problem and advise what I can do.
Thanks in advance
Thanks in advance
