Mercruiser MPI spark plug change frequency
QBhoy
Guys,
After the thoughts of the forum....
How often do we change the iridium and bloody expensive plugs on the above ?
Local Merc dealer reckons only when they noticing need it and not every year...
Thoughts...?
Ayuh,... Wouldn't hurt to look at 'em every 500 hours or so,....
QBhoy
Hey Bondo....a privilege to hear a response from you...
I tend to agree.
The boat is a 2003, but only covered 350 hours. 200 of which, I have had the pleasure of putting on her in the last 2 seasons.
I changed them this spring and I'm pretty sure they are the original. Seemed to make a difference to performance and even the sound of her. Just that little bit sweeter running.
Noticed a slight speed increase, although this could also be the result of a clean and waxed bum !
Went with the AC Delco....is there a better equivalent NGK that you might recommend?
Ayuh,.... I've run plain ole AC Delco MR43T plugs 500 hours, 'n the corners were just barely burnin' off,...
So long as the corners are sharp, it's still a Good plug,... the point on yer's,...
I worry more 'bout other brands rustin' into the head, 'n breakin' off,...
The MR's are an alloy body,...
QBhoy
Thanks Bondo.
They seem a bit delicate these iridium AC Delco plugs ...in comparison to the old ngk BR6FS I used to know and trust for the old 4.3 carbs.
