Mercruiser no start!!! Help! Covered all obvious bases.
zaxblue
1989 Mercruiser 4.3l 2bbl
No start! Has spark and fuel. What else?
Went through everything. Covered all obvious bases.
Seriously, went through everything from completely clean dry gas tank... New/clean fuel filters, made sure carb was completely spotless inside, new iGnition compomponents, etc.
carb bowl was full of fuel when I opened it up the first time. After going through carb, it ran perfect for 10 minutes. Wouldn't start again after I turned it off for a few minutes. Went through everything again.
No start this time. Will run for a couple seconds on started fluid if I crank it for a while. Even that is a struggle. Normally starter fluid lights right up in this thing.
Curious if full carb bowl is normal???
Starting to think I may have exhaust blockage???..that's all I can think of at this point
Suggestions???
zaxblue
float bowl was full both times I opened the carb. Mechanical fuel pump is working and pushes fuel until the float valve closes when the bowl fills.
Bt Doctur
ok then, pour 2 Oz of gas down the throat , if it runs double check your fuel delivery
zaxblue
Thanks for your help! Unfortunately, I don't understand the advantage of gas over the starter fluid I used.
Bt Doctur
gas tends to burn ,ether(starting fluid) explodes . Used aggressively it will put holes in pistons
thumpar
Sure does sound like a fuel issue to me too. Since it ran after cleaning the carb you may try a rebuild kit.
paul.detlaff
have you tried setting the idle to a higher rpm or put the throttle to 50% when starting it. i usually have to run mine at 1200 rpm until the engine warms up.
zaxblue
Even though every jet and orifice was spotless the first and second time I went through the carb, I picked up a carb kit today.
Just got home from work. SHE STARTED RIGHT UP and is running fine. THE HECK?!!
I run this thing at least 20 hours a week from May through November. Intermittent problems are my biggest aggravation. Hate to just cross my fingers and hope instead of figuring this out.
Any suggestions?
I would assume that if she was just flooded, if I got it to run an starting fluid for a couple seconds, that would have dried the cylinders. But would love someone to tell me it could have still stayed flooded after that. Ha. ???
I'm stumped.
zaxblue
Just to clarify incase I didn't make it clear...I did NOT install the carb kit I just bought.
zaxblue
Update
Ran perfect for about 30 minutes. Died Won't run. Went through fuel system again. Still no luck.
Important: will start for a couple seconds if I pump the accelerator pump.
Anyone?
Ayuh,...... Welcome Aboard,..... It sounds like a fuel delivery issue, so why haven't you rebuilt the carb,..??
zaxblue
Yes, it does sound like a fuel delivery system issue. That's why I've opened up the carb three times.
Carb was rebuilt less than a year ago. every jet and orifice was spotless. I did a half rebuild last night? Everything that was accessible After removing the airhorn. So, fuel filter, several gaskets, accelerator pump, etc.
UncleWillie
Runs with ether.
Carb bowls have gas.
Runs pumping Acc. Pump.
Does not run normally.
This indicates that the fuel in the bowl is not reaching the throat.
The jets are plugged or something similar.
If you pull the plugs you will see that you are not flooded. Dry Plugs.
Put a piece of Plexiglas over the carb opening to form a see through choke.
The venturis should be dumping like Niagara falls while cranking.
