Mercruiser Oil pump
baja23
I have an '88 Baja Sunsport with a Mercrusier 4.3L LX. I have a new motor I am putting in, and need to get a new oil pump as the one I have is a bit clogged. Does anyone have a part number for this? Thank you for your assistance!
zbnutcase
Re: Mercruiser Oil pump
A bit clogged??? Huh? Pump is same as Chev small block V8 'nutcase
Bt Doctur
DO NOT INSTALL A HI-VOLUME PUMP,
Use the standard one and yor motor will last
Ayuh,.... If it's a New motor,... Just What is the oil pump Clogged with,..??
If it's a Used motor,... What's it Clogged with,..??
I'd think the rest of the motor would be Clogged with the same Stuff...
