Grub54891
- Joined
- Jun 17, 2012
- 6,394
Well, you do not have the upper cap screwed down, is there oil in it? There is water leaking from the stb side housing,where there should be a gasket, and no water coming from that area. Torque the cap to specs, and fix the leak, and make sure there is gearlube in it before proceeding any further. Hopefully you didn't damage the gears and seals running it that way.
