hi,hoping i could get some help, really a bit frustrated with this engine. it is a 1978 Mercruiser 470
ive had an overheating problem that i cant seem to fix.
reading extensively on here, ive done the following in the last few weeks.
installed
new lower unit water pump kit
160 degree thermostat
water temp gauge
upgraded 4" heat exchanger
electronic ignition(ditched the points)
timing was pretty advanced, so i turned it down to about 8-10 advanced now.
engine gets to over 210 idling at about 1500 rpms.
this cant be normal? i ruled out that my exhaust riser is clogged as i see plenty of water coming out of my propeller etc, but is this all that is left to check? where exactly do you pull this part from and will i need any new gaskets when putting it back?
thanks alot in advance for your response!
Jaymie
installed
water temp gauge
Jaymie
