Baylinerchuck
Thread starter- Joined
- Jul 29, 2016
- 2,740
1990 Mercruiser 4.3LX, Alpha 1, Generation 1. I just discovered an oil leak that I think is coming from the hydraulic lines that pass through the transom plate. I think the leak is right where the hose is crimped to the stainless steel tube at the transom plate. This is a little discouraging since these lines were installed earlier this spring during my Chap's restoration.
Is it possible to replace these hoses without much hassle. If I loosen the distribution block off the bottom of the gimbal housing, I can barely get to the compression fittings that secure these lines. Anyone have any advice?
I'll use a bore scope to look at this further. Just looking for some tips here.
Thanks much.
Thanks much.
