CableGuy1978
Thread starter- Joined
- Jul 13, 2010
- 66
Hello,
Tried searching the threads for an answer but unable to find exactly what I am looking for...
Having some problems with my power trim. The outdrive is currently off the boat as I have replaced the engine coupler, and awaiting alignment. I have had problems with the tilt not working so well on the Up, but worked find on the Down. I took apart the switch on the shift lever and tried touching the wires directly, which did activate the pump. However on Up, the pump seems to be working hard as it runs a lot faster on Down. There is no load on the pistons either, and there is no movement from them on either direction when the pump is on. I am trying to troubleshoot the cause. I am also having difficulty identifying the type of pump it has as the ones in the manuals don't look the same.
Is the reservoir supposed to completely filled, as mine appears to be between 1/2 and 3/4 full.
Also I hear tell that these systems are supposed to be self bleeding as air in the system was a concern as well.
How likely is it that both pistons have seized. The boat has sat for 2 years steady in storage outside.
I had it to a marine shop awhile back for the same problems and after they charged me for some sort of repair job, I never got to try it out as I had a bad coupler and no money to fix it at the time. So I am going at it myself, and looking for some direction.
Thank you for taking the time to read this far, and for any info!
