Mercruiser R Drive. What kind of lube?
egleas84
Its a 1983 120 with R drive (im Told) What's recommended/best? I can get Quicksilver High Performance locally or just use 80w90? The stuff that came out was a very nice green color.
Re: Mercruiser R Drive. What kind of lube?
Ayuh,... 80W-90 hypoid gear oil will work, but I prefer Syn-oil...
I use Mobil 1, 75W-90 myself...
egleas84
Can i use syn with such old seals? Did you have to get the Mobile from a marina? What's a hypoid?
I bought Penzoil 80w90 before I questioned it. I'd rather go expensive on the lube if it'll be better for it. If not then 80w90
Hypoid gear oil is what you bought...
Penzoil sells the same oil as the Mobil 1, if ya look for it...
If the seals leak, it Ain't the oil's fault...
egleas84
It's snowing... I'm goin lookin for it!
Thanks again Bond-o!
Don S
Don't forget, you can also use the Mercruiser Hi Performance gear lube as recommended by Merc. It's also a wally world.
HT32BSX115
Some of them.............. Puyallup and Bonney Lake WM Don't carry it:mad:
egleas84
Got it @ Farm & Fleet in Janesville WI.
