fibersport
Thread starter- Joined
- Jul 18, 2010
- 104
I am installing a cooking system from an old MIE 230 inboard engine, S/N unknown. It originally was a LH engine with a gear reduction which changed the prop rotation. I am installing the cooling system in a RH rotation engine. I have opened up the raw water pump and replaced the impeller putting it in the correct direction for a RH rotation, I have also switched the inlet and outlet hoses from the standard rotation - and checked that the pump does indeed pump water into the original outlet side of the pump.
I have not started the engine yet as I am not finished but does all this sound correct? From the looks of the pump, it is symetrical so I'm thinking it is bi-directional with the exception of the inlet and outlet markings.
A little assurance that I've done it right?
Greg
Greg
