Mercruiser Sterndrive Gear Oil Leaking by Prop
1985 Century Mustang
I have a gear oil leak coming from the propeller. When I removed the Leg last week, it wasn't leaking. I went to put it back on yesterday, and noticed it was pissing oil everywhere by the prop. I'm assuming it's a seal. Question: Is this a hard job to tackle by a newbie? I have some mechanical skills. My Sterndrive is a Mercruiser Alpha One Gen One. Do I need any special tools, and are they expensive? Any videos, advice etc would help. Thanks.
look in these links for the special tools.
you will be pulling the bearing carrier
Thanks for those links. I'll check them out, and see what I can find.
It seems I have a leak in the upper part of the sterndrive, I noticed oil is coming down the shaft. Guess I'm going to need to do a full seal, gasket job now.
Question: Can a newbie accomplish this? I'll give it my best. I built a makeshift sterndrive stand today in my backyard, it works for me. I sure wish I had a garage.
Drained the gear oil, removed the lower sterndrive bolts, almost freed, however i need to get a 3/8 Allen Key for the zinc, I don't have a size that big. Harbor Freight will have them. I'll get there today20230609_190614.jpg20230609_192144.jpg.
nola mike
Drained the gear oil, removed the lower sterndrive bolts, almost freed, however i need to get a 3/8 Allen Key for the zinc, I don't have a size that big. Harbor Freight will have them. I'll get there todayView attachment 381072View attachment 381073.
Good news is that the seals in the upper are much easier to replace than the prop shaft. With a gen 1 you can pressure test the halves separately and see where you're leaking. I wouldn't mess with the input shaft seal, but I'm sure others would. It's not a bad job if you have an earlier style drive, otherwise it's a bit more difficult and you need a dial torque wrench ($$). Probably will need to replace the upper and lower driveshaft seals. You'll need the special wrench to remove the big castle nut on the input shaft. Cheapies on eBay.
Grub54891
With the oil drained, pressure check the drive first. spritz of soapy water will show you where it’s leaking. Shift shaft is rather common on those, easy fix if that’s all it is.
@Grub54891 and @nola mike . Guys can you identify this part. I'm not sure if I need to replace this also, I'm doing my water impeller. I don't want not to leave this out if it needs to be replaced. It's that metal piece with the notches around it. Does this need to be replaced too. Just checking. 20230610_121825.jpg
This shaft O ring on the lower unit was really loose. Could this have been one of my issues with regards to the leak?
Scott06
View attachment 381089View attachment 381090
You are not supposed to put that oring back on vertical drive shaft. Merc used them
Originally and found they tended to damage the drive shaft seal when putting the two haves of the drive back together
The first photo u have of the shift shaft that seal can Also leave best to pressure test the drive and see what leaks or do a complete reseal
I just replaced the water impeller a little while ago, for the first time. I just found a bad lower oil seal on the upper half of the drive, it's in the water pocket area. I ordered a new seal and the seal driving tool. I think I may need a bushing too, it looks like it's missing a rubber bushing as well as it looks like it's missing more than the seal. Your thoughts. 20230610_155822.jpg
Thank you. I'll remove it.
nola mike
So you can see that damaged o ring on the gear shaft, looks like it got caught in that lower seal (which is why Merc deleted it). That seal keeps water from the upper drive shaft. Good chance that the shaft is rusted/damaged. If so, you'll need to install a speedi sleeve on it if it's grooved. You can drive the upper seal in with a socket if you haven't already ordered the special tool. The shift shaft seal in the lower can be a pain; you can pressure test the lower separately to see if that seal is leaking
Thanks for the input.
dubs283
Yeah, a lot of folks post regarding the o ring on the drive shaft needing abatement.
If mercury has disregarded the o ring I've never heard of such, it's still provided with the oem w/p kit and always gets installed on my bench. Never once had an issue regarding the o ring after hundreds of installs, ymmv
Funny question, does any long time poster on this forum know the reason why mercury uses the o ring?
Do I have to use that 3/8 Allen bolt on the Stern Anode, or can I use a regular stainless bolt? Mine is pretty crusty and I don't want to put it back on. They are rather pricey too, just for a dang bolt.
Grub54891
@Grub54891 and @nola mike . Guys can you identify this part. I'm not sure if I need to replace this also, I'm doing my water impeller. I don't want not to leave this out if it needs to be replaced. It's that metal piece with the notches around it. Does this need to be replaced too. Just checking. View attachment 381086
yes, that is the shift shaft seal I mentioned. They make a tool for that also, common place to have a leak. You can pressure check it by holding your finger over the quad ring hole and pressurizing it, 15 lbs is all you need for testing. good to have a helper but I do it regularly by myself. Spritz with soapy water and it'll bubble if its leaking. Jiggle it around as you do so. The o-ring is deleted on the upper shaft as explained earlier. Use a stainless bolt for the anode.
Scott06
You wont be able to get a socket on the annode bolt if you use a hex head bolt, hole in outdrive housing is too small . Clean yours up with a wire wheel or die.
if a sockethead cap screw is too pricey boating may not be a good hobby for you
Grub54891
Ugh. yeah that's what I meant. Should have said allen bolt. oops...
